12 pack?
Longgone
John/68 Barracuda & Dart
Newport News, Virginia
Check out this vintage 6 x 2 carburetor set-up found on Ebay. And you thought tuning a six pack was a pain in the ***.:toothy10:
I have seen 4 4BBLs on a 383. Made for full throttle running at Bonneville.
Try to play with this set-up.
I wonder how many people saw the title and thought this was a thread about beer? 8)
Not me. I knew exactly what it was. Granted, I was hoping they were 97s but it is still an incredible setup (even without all of the other components). I am going to go after it. :)
Long, thanks for the link (it worked).
Not shown in the photo, but seen on other early log-type multicarb manifolds are the crossover (equalizer) hoses from the left-side manifold to the right-side manifold. Typically they were just rubber hoses connected by hose clamps to the stubs seen on the manifold body below the carbs.
GTXperience - that setup would be a great way to hide some stealthy FI on a 440.
By the way, going to MATS? Hope to see you there if you go.
OC, I won't be a MATS but will search you out at Spring Fling. Enjoy the show.
Finally found the picture that I was looking for. Courtesy Of Mopar Action 8/95
Ramcharger, Ever seen what happens when a newbie completely disassembles a CBX carb assembly???
Very cool! A genuine Barney Navaro piece! I wonder how many of these he actually casted.
I can only imagine..... :-D:-D
OOOHHHHH DRAG STAR LOG INTAKE!!!!!!!!! I want to build a log intake for the 360 that is going in my 53. I need to set my wire feed up for aluminum.
I was looking at a number of those early multiple carb log intakes at the Garlits museum last week. One was certainly a shop prototype as it was welded from aluminum stock and another seemed to be a production casting based on the first design, they were so close in appearance. There is quite a bit of history at that museum.
