Royalbull@73
Anyone here willing to let me know what is the widest wheel and tire that will fit under a stock 1972 Demon?
Thank you for the pictures and the reply. And yes I was referring to the 4.5" bolt pattern. I am changing the front brakes to discs. Staying with drums on the back. Decided to go with the 4.5" BBP instead of the 4" SBP that came with the car. I am going to have to buy new wheels but as of yet not sure if I get Cragars or try and stay with the original Rallye's ?Just for clarification, you talking 4.5 bolt pattern or wide? With the right offset, the choices are many. Depending on the look you're going for, 6" fronts & 7" rears are easy.
70 Duster with 6" frt & 7" deep rear. Back was tight on the fender lip, but a standard offset is no problem.
I should start looking for the rallys 15X7's then as I prefer that look over the others. I have the original magnum 500 14X7's off of my Challenger that I could use but like you I don't really care for that look on my Demon. Thank you for the input I appreciate it.If you decide on a traditional style rallye, i'd definitely look to the used market. 15x7's should be out there, mainly from B & E bodies. New repro's in just about any size you want are available, but by the time you trim then out, it'll be big bucks.
With some exceptions, i don't care for Magnum 500's on A bodies, but i'm sure there are some used deals around if you like the 5 spoke design. They are all 4.5" so 6/7" wide should be out there.
Pic from this site in 2010...lol. Not bad imo.
