14" X 4.5" wheels and tires for 1972 Demon
Royalbull@73
California
Anyone here willing to let me know what is the widest wheel and tire that will fit under a stock 1972 Demon?
Just for clarification, you talking 4.5 bolt pattern or wide? With the right offset, the choices are many. Depending on the look you're going for, 6" fronts & 7" rears are easy.
70 Duster with 6" frt & 7" deep rear. Back was tight on the fender lip, but a standard offset is no problem.
Tried to post a pick for you, but it doesn't want to go. :BangHead:
There you go. Twice, lol :)
Thank you for the pictures and the reply. And yes I was referring to the 4.5" bolt pattern. I am changing the front brakes to discs. Staying with drums on the back. Decided to go with the 4.5" BBP instead of the 4" SBP that came with the car. I am going to have to buy new wheels but as of yet not sure if I get Cragars or try and stay with the original Rallye's ?
If you decide on a traditional style rallye, i'd definitely look to the used market. 15x7's should be out there, mainly from B & E bodies. New repro's in just about any size you want are available, but by the time you trim then out, it'll be big bucks.
With some exceptions, i don't care for Magnum 500's on A bodies, but i'm sure there are some used deals around if you like the 5 spoke design. They are all 4.5" so 6/7" wide should be out there.
Pic from this site in 2010...lol. Not bad imo.
I should start looking for the rallys 15X7's then as I prefer that look over the others. I have the original magnum 500 14X7's off of my Challenger that I could use but like you I don't really care for that look on my Demon. Thank you for the input I appreciate it.
