15/16 master cly
Dakota_Don
where to get one.. I need one for my 68, and the autoparts are N/A right now.. the brake system is non power disc/drum.. and a 4 stud (bolt) master cly.. should i convert to a two bolt,like from a ford or dakota.
thanks
Don
Check with CarQuest,that,s where I got my dual 4 poster.I then switched to a 4 poster off a Dakota.(lighter)
did that to.. no luck
I found one at a local car show. The box has 2 numbers on it.. 11516 and F79772. Check with NAPA, they might be able to cross reference one of the numbers. Your best bet might be the adapter and the 2 bolt MC. I hope that helps. One word, don't let them (NAPA) tell you the early drum brake MC's interchange. THEY DO NOT! There is a residual valve in the rear bowl to hold 10 lbs of back pressure on the brake shoes. If you try to use it you will find your disks locked up, ask me how I know. There might be a way to remove the residual valve and maybe someone here knows. Good luck!
