JohnBeGood
New Member
- Joined
- Jun 14, 2008
- Messages
- 4
- Reaction score
- 0
Whats the latest and better way to install this in a 68-69 fastback barracuda? Tubular front end? Motor will be blown! I would think that it would be to much weight up front...
You are probably right-I dont want to spend my retirement money to do this kind of project! I will just find a different car that would work better than an A Body.Drop it off at my house. You won't have to worry about a thing.![]()
Yeah but then he loses the Hemi status.
I put a 392 in a 63 Valiant using a mustang front end, vary tight fit, boat style pan, a lot of engine compartment alterations and blood.Whats the latest and better way to install this in a 68-69 fastback barracuda? Tubular front end? Motor will be blown! I would think that it would be to much weight up front...
----same here, I`d take it !Drop it off at my house. You won't have to worry about a thing.![]()
Ears on the side of the Early Hemi block are the same as an A motor. Just bolt it in with normal 273/318 mounts
