[WANTED] 1962 Valiant rear axle
got one l just pulled out of a '63 Valiant WAGON. Unknown ratio ( but l can check if really interested).
Also one in a 62 Valiant out back. Still in car.
Also one in '62 Dodge Lancer. Still in car.
Located just outside Charlotte NC as well. - Concord.
I believe later ( '67 up ? ?) Are wider.
They are out there.
Just depends on how bad you need one.
I have a 63 Valiant with the rear still in it. It was a 6 with a 3spd manual. I don’t know the ratio but can check. The car is on the west side of Baltimore Md.
I believe all 7.25 diffs are the same from 60-66 and will fit all those years. 60-62 rear springs may be different than 63-66.
The front spring mount is different in 60-62 A bodies. If I'm wrong chime in.
Dimensionally all 7.25 rear ends are the same from 60-76. There are differences in brake size, wheel bolt pattern and e-brake cable length depending on year/car originally installed in. If installing drum to drum, on your existing springs they all ('60-'76) bolt right in.
