1962 valiant shifter change
MLP
Florida
What keeps the shifter from going by the gates for 1st/reverse and 2nd/3rd gears and ending up in front of our behind the gate/ shift levers on the 1961 valiant floor shift?
Picture shows shifter and all components installed. What keeps the above from happening
Picture shows shifter and all components installed. What keeps the above from happeningView attachment 1715121161
For those interested, 1962 Plymouth Valiant V100 shifter and transmission change is complete. Thanks for the help to everyone involved!
Figured out the problem. shifter and tranny change complete on the 1962 Plymouth V100. Changed out the 3 speed manual column shift to 3 speed
manual floor shift. All components are date coded and correct from a 61 Valiant and it all works perfect.
Your thread is about to rotate into page 4, so I'm guessing, nobody knows. Nor do I. But I'd like to help you figure it out.
I've built hundreds of those transmissions, but I've never seen the sticks that go with them. Yours is a doozy,lol.
But first I'd need to get sense out of your question. I read it six times and so far I'm not getting it. So, if you still need help,and wouldn't mind, can you restate the problem in different words,lol.
Whoops, I see you got it while I was typing.
Congrats, you are now officially a HotRodder
No problem! Between the shifter levers and the shifter support bracket, I kept wondering what only piece left on the bench was for. The infamous washer goes between the support and the lever. That makes up the slight space that was present of which was allowing the posts on the shifter to slide past both brackets while shifting forward or reverse and into nomans land. The best way to truly understand it is to see the system in action while driving with the top boot removed.
As soon as I saw it all in action boom the lightbulb came and I sped back to the shop and installed the infamous washer.
