1963 Dart heater controls
63Dart170
AZ
I just bought a '63 GT for parts. I already have a '63 2 door post car. I was surprised to see heater controls are in a completely different location on the GT. The GT has the controls mounted on a pod below the dash and the post car has them mounted above the radio in the dash. I can't imagine why Mopar would have done this. Any ideas?
Could be some sort of air conditioning retrofit that used a delete plate for the regular heater. Pictures will help clear up what this is.
In the GT:
In the 170:
Now that I look at it like this I think someone moved the controls to the top when the aftermarket knee knocker A/C.
Sure looks better in the dash.
The Red car is a 64. I bet the 3rd digit of the VIN is a 4.
It's a '63. Wiper motor hump on the firewall.
Given the other weirdness I've found I wouldn't doubt if they changed the dash.
The car had a manual trans brake pedal and the clutch pedal chopped off.
That's a '63 with home-made move of the controls up to the '64 location. All '63 A-bodies had that crappy little plastic box carelessly tossed under the dash, like "Awcrap, the heater controls! We forgot the heater controls! Where'll we put 'em; this car has to be DONE!".
That sounds about right for the era. LOL
Off topic question for you Dan. How can I determine what size /6 is in the GT?
There are several ways, but let's try hitting two crawdads with one chopstick (engine size, whether or not it's potentially original to the car): what are the casting numbers on the manifold side of the block?
Thanks. I will take a look and see what I can find. I have no idea if the engine is original to the car.
