[WANTED] 1965 273 Alternator Bracket
BergmanAutoCraft
FABO Vendor
FABO Vendor
Hampstead, NC
Looking for an alternator bracket with AC (if it makes a difference) for a '65 273. I believe this is the one with the hole in it for the dipstick.
PM me if you have anything. Thanks FABO!
Yes, i have one. $23.00 plus shipping. Adjuster bar would be extra if you need it.
All the mounting brackets are the same '64-6 273 (and even poly 318's) A/C and non-A/C. The adjustment strap is different between manual trans and automatic for some reason. Not sure what the difference is or why there should be one, but, they have different part numbers in the factory manual.
I’ll take both straps if you have them. Let me know how you want to be paid. I’ll send a UPS label. Just need box weight/dimensions and address.
FYI poly 318 is different. two bolt holes vs 4 bolt holes. No problem though. Let me assemble and pack.
PM me with contact.
It's the same, that's why there are 4 holes in the bracket to mount it to the head. Part# 2463390
