1965 Dart issue!
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
On my 65 Dart GT convertible last something strange happened.
When I put the key in the ignition switch and either turn left (accessories) or right (ignition on) the windshield wiper starts! The windshield wiper switch is off of cause.
When I add a test pen between the switch and the body the test lamp goes on.
Does anyone have a good switch and can tell me if the power goes on the switch, which outlets should have power at that moment? I suspent the outlet to the backup light switch. And yes, my works too. But between my two switches I have power on two different outlets on them.
I can't figure out what the heck is wrong!!
Any help is gladly appriciated.
There is a park circuit that is energized, and is opened by contacts/ cam in motor gear assembly. Your switch is likely good.
If others agree, it might be time to pull wiper motor. disconnect battery (-) when doing that.
You need the FSM which shows the full schematic including what gets power and when.
