Hi! I got a '65 273 'Cuda with the V8 center link installed and at the moment the 273 oil pan obviously clears the center link. I also have a slant six center link in my '65 Valiant, and the main problem is all about oil pan clearance.
At the moment I am pulling my 273 drivetrain out of the 'Cuda and working on a nice '86 LA 360 small block build, and will use an automatic 727 trans with that motor in the 'Cuda. I don't have a motor in the '65 Valiant at the moment and just got finished with a '96 318 Magnum small block build for it, and will use the 904 automatic trans off of the 273 for this 318.
Anyways, I got to looking at my oil pan clearance on my 273 to the V8 centerlink and it looks like it has about 3" of clearance stock.
My main question is, can I some how get both of my center links modified a little to drop down enough to clear my oil pans, on my LA 360 and 318 Magnum oil pans? (360 & 318 have the same oil pans) They both do not have the truck style oil pan, that has been assessed and they both have the car-mid sump oil pans.
Comparing the 273 oil pan to either the 318 or 360 oil pans, it appears the rear part of the oil pan that has a difference of 2-3 inches (318/360 basically drop lower than the 273's oil pan). So has anyone ran into this dilemma before? What should I do? Rack & Pinion set-up is not up my ally anytime soon (price wise).
I've heard of some people using two center links, chopping the ends where it starts to angle down, and add more material from the other center link and weld it to make it longer. In this case I need both center links modified instead of one. Any suggestions, or comments would be greatly appreciated.
