[FOR SALE] 1965 Plymouth Valiant Signet Wheel Opening Moldings
sgrip65
66 Dart GT 273, 65 Dart GT 273 HiPo
Minnesota
I have a full set of 1965 Plymouth Valiant Signet Wheel Opening Moldings for sale. I am asking $200.00 for the set of four. Two of the moldings are very nice, and two are nice to less than ncie since they do have a few dings as shown in the photos. If interested, PM me at sgrip65. Thank You.
Bump
'65 Val will fit '65 Barracuda if the '65 Val had the '65 Barracuda rocker panels. If not, then you may have to cut a small notch to accommodate. I know '66 have this small issue. Also '66 Val were aluminum, '66 Cuda were stainless. I believe '65 were the same regardless, aluminum.
His '65 Val rocker panels should be the same as '65 Cuda. Design is correct. Just need measurements to confirm.
Maybe sgrip65 can confirm or another member what I mentioned so you know for sure.
Thanks. The 65 Valiant rockers, which I have, would enter the notches which are cut into the wheel opening. moldings. sgrip65
