1965 Valiant rear brake job parts list, missing anything?
ValiantKevin
Kansas
1965 Valiant V8 rear brake job parts list, everything look right?
Being I have the V8 I wanted to be sure. also am I missing anything?
If it's original, I'd change the rear brake hose too. When you have everything off, lube up the E-brake cables and guides.
Aside from the fact that rock auto is the queen of reselling Chineseum garbage parts ,
If you have an 8 cylinder —- you will find that you have
10 “ x 1 3/4 “ in the Rear —- you can measure and know that is correct in no time….
And everything you have listed is 1000 % incorrect….
That is all 9 “ for 6 cylinder…..
Most '65 A-body V8's came with 10" brakes, but, not all of them. I owned an early '65 Dart Gt 273 4bbl with A/C that had manual 9" all the way around. The OP's car could have had a rear axle change sometime in it's life too. (likely on a V8 car with a 7 1/4) Measure to be sure before you order.
