1966 Barracuda AM/FM radio part number?
ZooKypr
NJ
Anyone have info. and/or a pic of a 1966 Plymouth Barracuda AM/FM radio? Part Number? Model number? Correct me if I'm wrong but isn't there a third wire unlike AM radios, what modification is neccessary to make it work?
Thx, Roberto
To my knowledge an AM/FM was never offered on an early A. A 70's A Body knob style AM/FM fits a 65 Dart as I had one in my Dart for years. May fit a 66 A Body - not sure.
Yes, you could order one starting in 1965 for A bodies...Here's the pic of the factory AMFM in my old 1965 Barracuda "S".
'65-'66 Valiant FM-AM radio, model 372: 2661 687 (for '66 Valiant use with bezel 2580 748).
'66 Dart FM-AM radio, model 373A: 2808 952.
This would be the correct one for a '66 Barracuda? Would it look exactly like the one pictured by 1969CUDAMAN in his 1965 Barracuda?
I seen one similar but it was model 367.
Also how would you accommodate the third wire?
Thanks fellas
Yes.
Since I don't know exactly what his is, I can't say.
What third wire? I suppose I'd probably…connect it to where it needed to go!
What third wire? I suppose I'd probably…connect it to where it needed to go![/QUOTE]
Its been a while since I pulled my AM radio but I believe it had 2 wires and the am/fm radios of that time period had a third wire for a rear speaker which early-A Barracudas do not have.
This is what we did in Jason's car we're restoring.
We modified the factory early A AM face plate and put it over top of a 1973 Plymouth scamp AM/FM radio.
From a glance it looks factory and fits like a glove.
Just another option for an uncut dash and factory early A look
Here's a page out of the 1966 accessory catalog for Dodge. FM was not stereo I don't believe.
How'd you get chrome pushbuttons on a '73 Scamp radio? The ones I've seen have had black pushbuttons.
That's a good question Dan. Lol.
My uncle had the car for years, and parted it out about 10 years ago, so it's been a long time. Might not be the original radio to the scamp. But it was a pretty original car
To get a factory AM/FM radio in my 66 Barracuda, I had a set of black buttons plastic chromed to match the original AM chrome ones. Unfortunately, the AM radio buttons are not interchangeable with the AM/FM.
The original faceplate had round button holes. So we had to carefully trim them out to slide it over the square button radio.
While prorac1 did a very nice installation job with the AM/FM radio, based on the font on the faceplate of the AM/FM they used it looks more like a '66-'67 "B" body AM/FM than a correct '73 scamp one even if removed from a scamp. This would also explain the difficulty in exchanging buttons another member mentioned as I've not had a problem doing that between AM's and AM/FM's as long as the years were the same or +/- 1-2 yrs. approx. Agree with other members that the '73?- '76 style knob type AM/FM is the best solution for your '66 cuda as it has the same white numerals on a black background as your '66 cuda (and many others) and is a direct bolt in, including knobs and wiring, other than a minor mod on rear support brace if used. Never seen the third wire your referring to, and I've looked at many of these radios over the years from a large variety of years and applications.
By George! I think you found it.
Thank you for the compliment and for solving our radio mystery.
Eric and Jason.
Looks real real similar to the 1967 GTX radio in the pic above.
I apologize if I derailed the thread. But thank you for figuring out what our radio came from.
Although nerdy, I dig keeping track of all the donor vehicles it took to build a car. Lol.
Thanks again. Eric and Jason.
