1966 dart flashers
66Dart225
Active Member
West Hurley, NY
Hi all. I am having an issue with the front drivers side flasher. It is really dim and don't blink. I also noticed that when it is on the other side turns on dim to. The passenger side works perfect. I tested the power and ground at the socket and both are good. I dont know what it could be.
Bad ground I'll bet. I had the same problem. I removed the bulb, cleaned a spot and soldered a 12 g. wire to the socket. I ran the wire to a sheet metal screw to complete the ground path. The sockets are flared into the reflectors and through the years the connections corrode. tmm
