1966 Dart torsion bar info needed
SS Lancer
North Carolina
New to the torsion set up , does the same theory hold true for torsion bars like with coil springs in that 6 cyl bars are better suited for drag racing versus the V8 ones to aid with car lift etc ???
Just curious I just obtained a 66 Dart that was an original 273
automatic car and im building my for Super Stock racing so I need proper weight distribution etc please educate me thanks Chris .
yes, 6 bars are like light coil springs, lots of sag under a V8 to them so there is lots of movement up there.
Ok - I will start looking for a set on slant 6 ones
Maybe some will pop up on forum are new ones available? ??
Thanks Chris.
Thanks Chris.
Yes, you can get new bars at PST or Just Suspension...
dont get new unless your set on new 6 bars. Plenty of them should be on here as many go from 6 to 8 and thats the first conversion piece they pitch into the scrap pile.
A-body 35.8" 0.810" 90 P5249148 Drag Racing
A-body 35.8" 0.830" 100 N/A 6-cyl. Production bar
Thank you
What company would sale the A body drag bars u mentioned?
Thanks Chris
Thats a Mopar Performance piece. So little demand that PST probably doesnt make that one.
How about some photos of the 66 Dart? We're all photo junkies on here........
340 : 727 be pulled soon after fenderwell headers are successfully installed
Then cage
Frame connectors and floor pans installed then some fresh paint
u spent that much. unscrew torsion bars u have . is good front will raise on take off.weight when take off will transfer to rear
PS u months late from giving me the info
That's not correct, and the same stored lift energy applies, yes. 6 cyl. bars wound tighter will help transfer that weight back before the frt' tires get off the ground, or at least floating, stiff bars unwound only lower the ride height......which is worse because the the amount of lift will be less before they unload the frt tires........fine if You're running pro stock and have the tire for it and have to avoid standing it on the rear bumper,..but for most of Us.........
Thanks for the info
I will be running Super Stock
Class and running Super Stock Chrysler rear leaf springs with a Jerico 4 speed I need it to work right the first time.
