1966 fender tag decoder question
340CUDA69
Active Member
Ontario
Looking for a couple of fender tag code numbers. can't find these if you can help?
1966 top row - lower case letter under "W"- number 6
And middle row, upper case letter under "E" - number 3
Thanks. Tried.This service has been discontinued according to the site.
Anybody else??
The w is a "vehicle sales and delivery" code and the E is a "optional package" code. I don't know the codes though.
Thank you. Getting closer. Narrowing it down
These are the only 2 things on my tag l can't seem to locate anywhere.
Found E-1, which is an air cleaner package. Maybe something to do with that.
NOTHING on the lower case "w" except what you have shared.
Thanks again
Thanks again
The book I have gives a range of code numbers within that particular code letter but when you go to the code numbers within that range there might be 30 different possibilities. I think the optoion number on the tag is the last number of the 3 digit code. @Alaskan_TA is very knowledgeable about this stuff. Hopefully he will stop by and teach us a thing or two. LOL
GOOD to know. Otherwise, l guess l would have to go thru 30 possible options code to see if it is on my car. Every other code is correct, and verified on my fender tag except these 2.
Thanks again for your assistance
AWESOME. YOU GUYS FIGURED IT OUT. THANKS A BUNCH.
'E" WAS AIR CLEANER PACKAGE- AUTO PILOT
'W" MADE IN CANADA
CHEERS. STAY SAFE
