[WANTED] 1966 Formula S Leaf Springs build sheet number 804
dschem
Illinois
Hello,
I have a 1966 Formula S that at present has a set of the Super Stock leaf springs from Direct Connection. I am interested in trying to find an original set of leaf springs for my car.
The build number of the leaf springs is 804 which from what I understand should be the last 3 digits of the leaf spring part number.
Dave
Heello,
Thanks for the info but I am looking for an original set of leaf springs.
Dave
Mine are original, not for sale. But I'll try to get the numbers off them for you.
Hello,
I was told that the build sheet number is the last 3 digits so yeah it would be cool if you could check the number for me.
Thanks
Dave
Hello,
Dave
804? I can't find that in the book. Your spprings should come off the build sheet and not the fender tag. A Formula S should have the 6 leaf springs. Code 367
Hello,
yes I know the car did have the 6 springs but we’re changed out in the past and the original springs went missing.
the spring code on my build sheet is 804 for both springs.
Dave
66 Formula S, 4 speed rear spring # 2403804 both sides.
67 Formula S, 4 speed rear spring # 2835024 both sides.
Yes
I need the 66 springs.
thank you for checking.
now I just need to find a pair.
Dave
i will check my leaf springs on my formula s commando spare parts car
