[SOLD] 1966 Plymouth Valiant Convertible Rat Rod
Ratrod85
Active Member
Mebane, NC
$3700obo
Engine: Dodge 318ci with about 1500 miles on rebuild.
Wieland 4 Barrel Intake, Quick Fuel 600 cfm Carb, Summit Racing Cam #
SUM-6901, Comp Cams Valve Springs, Aluminum Radiator.
Transmission: Dodge 904 Automatic with 1500 miles on rebuild.
Trans Go Shift Kit, Stock Torque Converter
Rear End: Ford 9in Shortened with 3.00 Gears and new custom length axles
Front Suspension: Stock, New Lower control arm bushings, strut rod bushings, and upper control arm bushing. Factory Drum Brakes. New Firestone whitewalls.
Rear Suspension: Custom triangulated 4 Link with Coil Springs. Drum Brakes. New Firestone Whitewalls.
The interior has remained mostly stock, custom door panels and dash pad, aftermarket cd player, Custom Glove box Ice Chest. The orginal heater box is missing. Would need aftermarket box to provide heat.
The exterior is mostly stock except for removing the trim on the tops of the quarters, filling antenna hole in fender, and removing the drivers mirror.
The convertible top frame is all intact and in working condition. Needs to have viynl installed. Missing the power top accessories, cylinders and motor are avaliable aftermarket.
Subframe connectors have been welded to increase rigidity in the uni-body.
Any Questions Feel Free to pm me, all offers will be considered. No Trades please. Thanks!!
Contact Chris
Cool Ride.. Seat backs need some pin striping. Is that a manual top?
Thanks! Never got that far with the striping, and the top is only manual by default because none of the factory power top parts were there in the first place. I liked it more as a roadster anyway.
You sure couldn't build it for twice that... I am liking it..
Thanks guys for all the compliments! The gas tank is stock it is just painted black. It was missing in the pics due to welding and i bought a new one at that point in time. The rear is out of a 1961 ford truck i shortened. Defiantly a 9-Inch
