I found this untouched original in Western Arizona eight years ago. I've had several dozen 66 Valiants over the last 50 years as my favorite A-body. Including a V100 2dr that was factory built with a 273 Commando, 4spd. Sure Grip, Rallye Suspension, manual disk brakes and fast ratio steering. I've built them with 340s, 360s and even hot S6s often with all the chassis upgrades noted. This one was intended to be my final best effort but age and finances have stopped me. As you are likely aware, the V100 in 66 featured a full pan rubber floor over jute. If any moisture gets into the jute it is trapped under the rubber and rots the pan from the inside out. Finding one today with original floor pan intact is nearly impossible. I bought another one around the same time west of Vegas, lifetime desert car. When I picked it up, sure enough the floor was made of street signs. A clean good-looking car too. The AC had dripped water... There is surface scale on this one but it is solid. The body is unrusted other than some surface oxidation and shows original paint. The driver's door is lightly oil canned and the trunk lid is dented. Good replacements are included. It is a three on the tree slant six with a 70s 225 bolted in. I drove it onto the trailer. The car alone is for sale at $2500 Firm with clean Colorado title. Located in Bayfield, zip 81122.
There are numerous parts available that can be additionally negotiated. Once the car sells they will all be available but not prior.
Show chromed front bumper
NOS grills and headlight bezels
V8 tie rod center link
73-later disk brakes
8.25 3.21 rearend
Taillight bezels and lenses
Extra Heater box with excellent vent door and excellent driver's side vent assembly
Complete USCT Motorsports unit body reinforcement kit including mini-tub components
Schumacher V8 engine mounts
A-body bucket seats
Borgeson power steering kit from Bergman
New pitman and idler arms
Bits & pieces
The picture is after being unloaded from the trailer on arrival from Arizona. It shows road dirt before it was rinsed as it was towed through a rain storm. It has been stored in a shed since and I will pull it out once someone shows interest. A phone discussion is recommended. Thanks, VJ
8.25 3.21 rearend
A-body bucket seats
Bits & pieces
