1966 Voltage Regulators?
Early A-Body Discussions
  1. coalman
    coalman Well-Known Member
    783
    197
    Aug 6, 2015
    Texas
    Local Time:
    6:09 PM
    Have any you tested these on the bench with a multimeter? If so, how, I have three and want to check them. I have a long running Thread on charging problems under Electrical. Thanks
  2. memike
    memike Super Moderator Staff Member FABO Gold Member
    49,326
    9630
    Jan 8, 2006
    on the hill
    Local Time:
    6:09 PM
    Not sure why you don't just switch to the newer style regulator
  3. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    51,996
    20070
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    7:09 PM
    Think it has to be on the car per the 66 FSM
  4. coalman
    783
    197
    Aug 6, 2015
    Texas
    Local Time:
    6:09 PM
    I have two solid state ones that look like the original, and one reproduction mechanical. Thanks
  5. KitCarlson
    KitCarlson Well-Known Member
    2,444
    357
    Jan 17, 2008
    Middle Tennessee
    Local Time:
    6:09 PM
    A simple test is done using a bench top power supply with adjustable voltage, 3A or more current capability, a voltmeter and 12 volt bulb. The bulb is placed on the regulator FLD terminal, the other terminal on ground (regulator case). The power supply (+) is connected to regulator IGN, (-) to regulator case.
    Test as follows: Use meter to monitor voltage at IGN to regulator case. Set supply voltage to 12V, the bulb, should be lit, increase voltage slowly, the bulb will go out when the voltage is increased to regulating point, typically a few tenths around 13.8V. The bulb should turn back on as voltage is reduced, a bit below the regulating point.
    For new two field terminal regulators, the bulb is connected from FLD terminal to (+) power supply, not ground as in early regulator test.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • coalman
      783
      197
      Aug 6, 2015
      Texas
      Local Time:
      6:09 PM
      Thanks for response, I have been out of town or I would have responded sooner...
    • 67Dart273
      67Dart273 Well-Known Member
      39,793
      7408
      Oct 14, 2010
      Idaho
      Local Time:
      4:09 PM
    • coalman
      783
      197
      Aug 6, 2015
      Texas
      Local Time:
      6:09 PM
      Any suggestions for the bench top power supply? Thanks
    • 67Dart273
      39,793
      7408
      Oct 14, 2010
      Idaho
      Local Time:
      4:09 PM
      Egag, Mouser, Digikey, the smaller electronics supply, houses..........or find an old rheostat. You happen to have an alternator/ generator test set?
      18V 3 A Bench Power Supply | MPJA.COM
      30V 5A Digital DC Power Supply Variable Adjustable Lab Bench Test Equipment Tool 743828299538 | eBay
      BUT BE CAREFUL. This one is not "variable" but rather "selectable".........it has SWITCH POSITIONS
      PS-28A | ADJUSTABLE VARIABLE POWER SUPPLY BENCH DC OUTPUT 12V 9V 7.5V 6V 4.5V 3V 744633428489 | eBay
      This little kit will give you 1A output which may or may not be enough
      Variable Power Supply Kit | Alltronics
    • coalman
      783
      197
      Aug 6, 2015
      Texas
      Local Time:
      6:09 PM
      Thanks for all the input, how about the PS-28A, the price is affordable?
    • KitCarlson
      2,444
      357
      Jan 17, 2008
      Middle Tennessee
      Local Time:
      6:09 PM
      I have had good luck with Marlin P Jones. A quick check shows most of their supplies out of stock, at the moment. My 0-30V, 3A supply is 15 years old, works great. Adjustable current is a big help, it will hold that current with a short. I use it when checking wiring and electronics instead of battery. If I were to buy another, would get 10A unit. For large currents I use 20A 13.8V fixed supply for ignition and EFI development work.
    • KitCarlson
      2,444
      357
      Jan 17, 2008
      Middle Tennessee
      Local Time:
      6:09 PM
      The PS28A has voltage steps, it will not help you test regulator.
    • coalman
      783
      197
      Aug 6, 2015
      Texas
      Local Time:
      6:09 PM
      Not a win situation!! Thanks
    • coalman
      783
      197
      Aug 6, 2015
      Texas
      Local Time:
      6:09 PM
      Found this on "E" Bay DC POWER SUPPLY QW-MS305D, will this work??? Thanks
    • 67Dart273
      39,793
      7408
      Oct 14, 2010
      Idaho
      Local Time:
      4:09 PM
      Link?
      LOL that is what I posted above. I can't speak for the quality of these, but the specs indicate it should be adequate. You might google the "model" and look for reviews
