1967 Dodge A108 Tradsman Camper Van
cccikevin
New Member
cedarpines park, ca
Rating - 0%
0   0   0
hard to find VAN!
V-8 Automatic Tradesman Van with camper pop up, built at Windsor Truck Assembly
Runs, needs oil pump & gas tank hooked back up, the rest is basically cosmetic. As you can see by the pic's very clean as var as body dents.
Miles 88245
Specs:
Rear Axle 3600 35 RA36
Rear Springs 1410
Front Axle 2500 3auto A727
Front Springs 1200
GVR 5400
"New for the A100 in 1967 was an even larger 210-hp, 318-cu.-in. V8 replacing the 273-cu.-in. engine. New safety regulations saw the addition of a padded instrument panel, padded dual sun visors and a dual braking system. A different look came in the form of optional rear quarter windows available as part of a custom cab package, or separately. Other optional niceties included a cigar lighter, a driver's armrest, a chrome horn ring and extra interior sound and heat insulation. Bright-finish hubcaps were also offered. An expanded 108-inch wheelbase was available on van and Sportsman models only."
2500.00 OBO
Cedarpines Park, Ca 92322
