1968 340 Block Crank J Heads Intake
gtsjohn
Ohio
1968 340 Block Crank J Heads Intake, block is standard bore, casting date 6/22/67. Standard crank with dampner, J Heads, 202 large valves, intake manifold, windage tray, $900.obo VIN W34023840410
[post deleted by staff -- please dont comment in for sale threads -- questions about the item only]
1968 340 Block Crank J Heads Intake, block is standard bore, casting date 6/22/67. Standard crank with dampner, J Heads, 202 large valves, intake manifold, windage tray, $950.
If everything is std that seems like a good deal to me. Any pistons and rods that go with it? What is the VIN on the block?
Probably no VIN as that is for an early car. I wish I were in the market and you were closer, but... I still need to check my trans for a VIN (8/28/67 SPD), but I don't think it has one.
if you post any more derogatory comments you will find yourself on vacation for a week...only warning you will get.......Wagg's
are u on crack or were they built with gold last week how much for the windage tray
and bolts and mabee the valve covers
