1968-69 340 timing cover
I don't have with marks on the passenger side. The one I have has no marks on it. I thought there was a tab that went with it.
The no-boss type is early '68 and earlier 273, 318, and 340. They use a bolt-on timing tab. Very late in '68 they went to the cast-in timing indicator and all '69's used them. Then in '70 they went to the drivers side indicator.
Thanks, Mark
Thanks, Mark
Those are also date coded if you are really picky. i have one off a 68 motor with the 67 date code.
Late '68 was the same as the '69.....cast-in timing marks on the passenger side.
Thanks, Mark
That must have been very late '68 then. I have one that I media blasted and noticed a crack that needs to be welded. Otherwise, it is in very nice condition. $25+SH. This is just in case you can't find another.
i have a late 68 to 69 t cover that is in great shape.
these are hard to find in this condition, just needs a little cleaning. no corrosion at all
