[WANTED] 1968-69 Dart Ignition Switch Pigtail
carguy47
Phoenix, Arizona
Hello FABO, I have been unable to locate anyone who repops these connectors?
Plenty of GM connectors, just not Mopar.
Is anyone familiar with some remanufacturing the ignition switch pigtail connector?
thanks
I know that a 68 cuda connector is different than 69 cuda due to the lower dash pad in 68. Hence the ignition switch was different. Maybe the same for darts, fyi.
Yes, 69 is one year only. I have lots of parts harnesses laying around if you can't find one soon I can ship it from Illinois.
This is on the dash side of the harness if it will work for you let me know. There are only 3 wires connected to it but there are 4 locations? Also not sure it is the ignition switch connector, but it was the only one that looked close to correct.
