[WANTED] 1968 a body 4 speed pedals
I think there are three different flavors of pedals, bushings vs bearings and return spring set-up. Just a heads-up.
And at least two different style of clutch pedal in 67 - 76. On one the arm is shaped different than the other (perhaps this coincides with the different ratio mentioned above?).
Generally though any 67 - 76 clutch and brake pedal will bolt into and work in any 67 - 76 a body. Do you specifically need 68 vintage pedals for a resto?
I have a set
looking for 1968 a body 4 speed pedals shipped 91770
Are you looking for just the pedals or the whole assembly?
