Christian1
So I'm told I have 1968 A904 transmission. Cool. I know it needs rebuilt, Check Summit, and everything I see is 1972-1978.... Will that still work? Any modification I can do to make it work? Does anyone know where to get a Rebuild kit for the 1968 A904? I need all new everything. Seals, clutches, steels, gaskets, ext.
On top of that, now that I'm thinking about it, is there anything I should do while the transmission is apart to make it perform better? I'm thinking I'm gonna have 500Hp at the crank MAX. Probably not even that.
