- ok all park lights work. the right rear turn signal works, the left front turn signal light works but the other 2 turn signals dont. all four of the hazards work checked at the steering column 2 wires blink at the connection those 2 wires go up to hazard switch but were does the wire come from that goes to the back does it come from the hazard switch or somewhere else oh no dash lights either do the signals work off the round plug in back of dash
Think of the hazard as an "addition" and ignore it for now
1...Do the brake lights work?
2...Brake light switch power, and...........turn signal flasher power go INTO the turn signal switch. The switch selects what lamps are connected to what, that is........
"Centered" the brake light switch goes through the turn signal switch, and is routed to both rear lamps
"Left" turn the brake light switch is routed to the RIGHT rear lamp, but the LEFT is then connected to the flasher.
At the same time the TS switch also connects the flasher to the left front lamp.
3......Your dash indicators are branched off the front lamp wiring and simply go up to the cluster connector
4......HAZARD. This is actually simple.........
With the turn signal switch CENTERED, the TS switch connects both rear lamps togethre (for stop) and routes both of them to the brake light switch
Both front turn lamps are disconnected from anything else inside the TS switch
NOW the hazard switch is a special switch. It has 4 terminals. None of them are connected with it off, and all 4 are connected together with it "on."
Hazard flasher power goes to one pin
Left front lamp goes to one pin
Right front lamp goes to one pin
And the last goes to the brake light switch line
SO WITH the TS switch centered, and with the hazard switch "on".........
Hazard flasher power feeds into the hazard switch and is routed........
to left and to right front.........
and to brake light switch line,.........on into the TS switch, and back to BOTH rear turn / stop lamps.
If you get bound up, I would pull the hazard switch connector loose until you get the stop and turn lamps working, then ADD that connector and see what you have
Access the turn signal switch with a lamp or meter, and get yourself a diagram/ shop manual. You can download them free from MyMopar. Some of them came from here
Look up the colors you need, and go through and check brake and turn at the connector. If you don't have it there, then no need to "bother" the rear harness at first
