skep419
5.9 Magnum 4 speed afficionado
Yep
Yep
Hmm. I have Super Stock springs and it sits high. That's...tempting...
Put a couple hundred miles on over the weekend, scraping everything in sight. Took the lowering blocks out and raised the front 1/2”.
I think you've got it backwards. The extra .2 degrees of caster on the right is for road crown (RF wheel is further forward than the left)You have 0.2 degrees more caster on the right than the left. If you can, reverse that so that you have a tick more caster on the left. The reason is the roads have a crown to them to help water run-off. In the Americas, we drive on the right, which means if caster is the same right/left, there will be a slight pull to the right. That ever-so-slight additional caster on the left compensates for normal road slant.
The problem is the package tray fills up with water so I can't have speakers, etc......UGH! at least your feet won't get wet...
doppelganger!
