Fan didn't work. Tracked it down to bad connector. (friends from work would be proud. Tracing wires like a boss hahaha).
Reverse lights didn't work. Tracked it down to corroded fuse holder tabs.
Have to replace fan connector, secure electric fan, install throttle return springs (left at work 24 miles away) fill coolant, fill engine with break in oil, prime engine install distributor, top off tank/bowls with fresh fuel, torque wheels, remove header plugs (mufflers hitting emergency brake) get friends and family together to say a prayer, have somone ready with timing light/screwdriver ready to turn up idle speed screw, pray again.
Well it's Facebook official. Tomorrow is the day the engine gets fired up. The girlfriend is inviting all our friends and family over. My birthday is next week so figured we'd make it into a engine break in/ birthday party.
Primed the engine. Coolant started coming out of the thermostat housing. Which I didn't really care about but than I noticed coolant coming from the center of both heads. Then to make matters worse the rear main is leaking as well. Looks like it's coming back out.
Also when using a razor blade to cut the right stuff gasket maker between the intake and the block. Be sure not to use the first one you see that has two pointed ends for a utility knife.
