Lord Sparky
The car had been running great but stalled twice yesterday. I was waiting at a light when the engine stalled without warning. I was able to get it going but it took some cranking. I pulled into a side street stopping and going a few times to see if it would happen again. It did not stall until I started slowly up a small hill and it stalled more violently (sounded like dieseling). Again, I got it going with some cranking and was able to get it home without stalling again. It seems to run fine: idled and accelerated normally. All the gauges were normal when it stalled: temp, oil pressure, rpms, and a normal 14 volts. No unusual sounds coming from the engine. Oil fine, nothing looked wrong on a quick inspection.
It feels like more of an electrical problem than a fuel starvation issue. New within the last 6-12 months: AVS2 carb/fuel filter, Mopar Performance distributor rebuilt/tuned by Joe White/wires and plugs, gas tank/sending unit, Promaster one-wire alternator/battery. If the engine had stalled out of traffic I could have checked if the carb was getting gas, but I could not. The mechanical fuel pump came with the car and has not been replaced.
When I first got the car, the engine stalled suddenly once when the car had the headlights running on 10 volts. I attributed this to the orange electronic ignition box not getting enough juice. With the new 95-amp Promaster alternator, the voltage has been a steady 14 volts.
A few hours before this happened, I was about to order a new FBO electronic ignition box/coil/and ballast resistor bypass wire, but they are closed Fridays. I though an upgrade would be good. I will order on Monday.
The question is: Is sudden stalling a symptom of a bad orange ignition box? I guess I will rule this link out once the FBO unit is delivered and installed, but asking now?
