Lord Sparky
The switch on the pull parking brake is not connected to anything. There is a unused connector with two black wires going into it that is located to the far left of the dashboard next to the wall and near where the parking brake bulb is. The wiring diagram seemed to point to this connector as the one that should go to the parking brake switch (since the wires are wrapped it is difficult to be completely sure). I tried to short this connector to a ground and the bulb did not go on. Ignition switch was turned to ignition. Note: The instrument cluster is removed, but this does not seem to matter in the wiring diagram. A simple ground short to the negative wire going to the bulb should make it light. Anyone know where the parking brake switch is connected to and is the parking brake switch the same as the door/dome switches (single wire to ground)?
