For Sale: Numbers matching 1969 Dart Swinger 340. I have the original engine, transmission and rear end. All 3 have been rebuilt. This is a 100% rust free California car. All original body panels, floors, rails etc. The numbers are stamped in the radiator support and trunk lip as they should be. The body work is done and partially blocked to 600 grit wet. Finish blocking, seal it and it is ready to paint. I run a body shop for a living with 35 years experience. So when I say it is basically ready for paint you can believe it. The car is completely disassembled for a complete nut and bolt restoration. The bottom of the car was stripped to bare metal and has been sprayed with the correct color epoxy. I will list below a description of the car and the parts I have with it.
The car is Y4 light gold metallic black interior, vinyl top and tail stripe car. Again, the original 340, 727 automatic transmission and 8 3/4 3.23 rear end. It is a factory A/C car as well. The photos with the fender tag show the options the car has. It is also a factory hood pin car as well. As seen in the photos I have the fender tag and a few small pieces of the build sheet but there is not much left of it. The car has been authenticated Galens tag services to verify exactly what it is. Photos attached. I have many new and restored parts as well. The interior is pretty much complete but needs to be replaced. The California sun did it in. I have the under dash a/c components. I do not have the under hood parts for the a/c. You will not find a more solid 1969 340 car anywhere.
New and restored parts: restored correct number radiator, correct part number and date coded carburetor restored. Correct distributor needs rebuild. correct exhaust manifolds with heat shield. The following parts are all new: bumpers and brackets, headlamp bezels, marker lamps, hood mouldings, tail lamps, dog dish wheel covers. New leaf springs, complete front end rebuild kit, shocks, tires. New inline tube brake lines and fuel lines. I have all the original glass, minus the windshield. All window, vinyl top mouldings and rocker mouldings. Original air cleaner. There are many more new, restored and original parts to the car as well. I also have the paint for the car. PPG base and clearcoat. A gallon and a half of shopline basecoat, and 2 gallons of the best clearcoat PPG sells. My cost on the paint and clearcoat was $2200.00 dollars.
. My name is Clint. The car is located in Virginia Beach. I can answer any questions you may have and provide more photos as well. By the way, I have owned the car for almost ten years. I am asking $19,500 for the car.
