3forty
"Raw Power"
My '71 340 Duster has the stock factory cam and pistons. No problems running on 94 octane gasoline.Yes they did, but the stock 340 had leaded 100 octane. Good luck!
Of course not. The ethanol raises the octane.My '71 340 Duster has the stock factory cam and pistons. No problems running on 94 octane gasoline.
You are so incorrect, it's not even worth the time to correct you.IIRC the 68-71. 340 had 10. 5 to 1 compression ratio. So if those are
8 to 1 then you would be leaving at least
25 hp on the table, which translates to .25 second in the 1/4. If your going to race it and you are gotta get another tenth of a secind less racer, go for it. If its a street , occasionally strip
car, save your money, go with what you have.
I have a buddy that is always after the elusive tenth of a second. I stopped by his place one day and he was under his car with a small propane torch using it to heat the undercoating to scrape it off.
Why not you blast Everyone's else post. You think you are the guru of everything Mopar. Last time i checked 1 point of compression on a STOCK engine was 10 hp . Ive seen it in action. 10 horsepower equates to 1/10 second, these are not hard fast rules but approximations.. Look it up for yourself.You are so incorrect, it's not even worth the time to correct you.
In my opinion the HV oil pump is not required, put a standard volume pump on it and check the pump clearances.Thanks for all the replies guys, appreciate all the input.
I'm taking the block to be checked out this week and here's the recipe that I'm working on:
*Stock crank and rods
*Melling HV oil pump
*speed pro L2316F pistons
*stock 340 X heads with felpro severe duty head gaskets .0499 compressed thickness
*Comp 268 cam and Melling timing chain/gears
*stock valve gear
*Mopar M1 dual plane intake and 650 Holley DP
*Chrysler electronic ignition
* 1 5/8" headers with 2.5" exhaust (on car now)
Did I forget anything? lol
As I said I'm on a tight budget and can't afford excessive machine work and parts, I have to do some foraging to afford the new pistons lmao
This will probably be the last car I ever do so I want some power but also dependability.
Please give any input or ideas, I'm open to any. Thanks again
I'm not debating that. But TO debate that, you don't know squat without a dyno.Last time i checked 1 point of compression on a STOCK engine was 10 hp . Ive seen it in action. 10 horsepower equates to 1/10 second, these are not hard fast rules but approximations.. Look it up for yourself.
It's no problem. All "THAT" aside, I can tell you this for sho and for certain......Jeeze guys, I didn't want to start an argument or pissing contest. I was just looking for experienced advise because I'm an old guy but new to Mopar small blocks.
When I got my Barracuda the P-O installed a Torker 340, headers, some kind of RV cam and a junk single point chinesium distributor on a stock 318 with a beat 904 and the original 7 1/4 no gear one tire fryer, ran like ****. I put the 8 3/4 3.55 in, a 2 plane intake rejetted eddy 600 and it woke right up.
I'm on a budget and just want to try to get as much as I can out of the 340 without disappointment, I don't have the funds to take it apart and re do it if it's not a stout runner.
I will respect any input and appreciate any input but please don't argue over others trying to help.
Thank you.
Thanks RRR, alot of my reasoning is that I don't want to deck the block or shave the heads too much or at all if I don't have to. I don't want intake fitment issues and being a stock bore block that's been sitting around since 1975 it shouldn't have many miles on it or core shift like when the cam journals get crooked.It's no problem. All "THAT" aside, I can tell you this for sho and for certain......
REGARDLESS of opinions, if you blueprint this engine to a measured ratio of somewhere north of 10:1 with iron heads and that small cam, you will very possibly end up with some detonation issues.
That's why I recommended the lower compression pistons.....well that and because you already have them. To me, on a street car, the almost two points of compression are not worth the possible detonation issues. .......PLUS with the lower compression pistons, 9.5:1 is within your grasp with some mild head milling. That saves dough from new pistons and keeps compression more friendly.
But hay, you seem intent on pushing the envelope, so push away! I wish you luck. You can do it. A lot of people do. Hell, I did it with my slant 6......but I won't do it again. LOL
Thank you for all the input, its very appreciated and like I said I am waiting to talk to the machinist who just might tell me the same as you bud. He is very respected and puts out some really awesome stuff. S&S Performance in Farmingdale, Maine, look them up on facebook and check out Steve Clukey's duster 340 he built, it's a screamer. A little bit pricey though lol...........Thanks again
I love statements like this, when half the factors that affect detonation are left out.
Hahahahaha!!!! No boost, those days are over for me bud last one was a 68 Charger back in 2003 Back then that engine 440 with the Don Hampton 671 blower cost me about $6500 to build in my garage, I couldn't imagine the cost these days lolOP say it with me now.....booooooooost.
Timing? 10 degrees after top dead center.
Cam overlap? 110 degrees.
Chamber volume? 200cc's.
Post #21 .108 in the hole (about)I haven't read the whole thread, but I'm sure it's been mentioned. Do your own measurements (might require buying a tool or two) and find out what your compression is now.
Until you KNOW what you have now, you can't make an intelligent decision.
Yikes!Post #21 .108 in the hole (about)
I somehow missed this upon reading the post the first time. This could make for a sub 9.0:1 ratio, that is admittedly not ideal even for a low compression performance build.Post #21 .108 in the hole (about)
How come nobody told me that Dominic Torretto was on this board?
