[FOR SALE] 1970 383 engine
Doc's Equipment
New Member
Westfield wi
Rating - 0%
0   0   0
70 383 Mopar engine from a c body. Car is long gone. This is a low mileage engine that I ringed and bearinged some time ago. It was a runner when I got it. Planned to use it in my 65 but went another direction. Bore taper was in spec. Original bearings were pretty nice but I replaced them anyway. The heads are fresh 346 castings with viton seals and new valves. The springs and retainers are not something I would use, but I have set mp 077 springs and retainers to include. Also have a few other odds n ends to include. I installed new cam bearings but I'm not happy with the results. I used a cutter cam and they look rough, but a new cam turned fine. I believe I have another set i can include. I have a deep sump oil pan and pick up, timing cover, Erson hyd cam and I'm sure some other stuff I will include. I've kept it coated with fluid film, and kept it bagged but have moved a couple of times so I would clean it before use.
$1200
Located in Stoughton Wisconsin
Will trade for Mopar 65-70 b body 8 3/4 axle with sure grip, or similar condition 360.
