Hi all. Really need some help here. Just had A833 rebuilt, new pilot bearing , throw bearing, new clutch and pressure plate. The car has a fairly significant vibration at 60-70 mph. No vibration revving engine in neutral. Feel vibration on accel and decel. I have changed everything in car, motor mounts, Tran mount, engine (proper flywheel and balancer), changed rear u joint, took out pinion snubber to neutralize pinion angle. The only thing I haven’t changed is drive shaft and rear end gears in 8 3/4. New bear axles though. The gears don’t whine or make noise but the diff and driveshaft are only things not changed. I didn’t change front ujoint but no noise from it.
Really frustrated with this resto. Tires and rims were balanced on a manual balancer. The front end has had new ball joints, etc. I can feel the vibration right through the car and shifter. Any help would be greatly appreciated.
