[SOLD] 1970 Dodge Dart Custom
Steve77
Active Member
North Carolina
Rating - 0%
0   0   0
I have decided to sell my 1970 Dart. Original 318/904 car. Currently has a 360 magnum with speedmaster heads, Howard’s roller cam, Comp rocker arms with B3 racing rocker arm geometry correction shims, tight tube Hedman headers and also have a set of Doug’s long tubes, short block is stock. I do have brand new icon pistons with rods and crank that are all balanced and a rough bored 318 block standard crank and rods. Champion radiator, pertronix distributor and coil, AED carburetor, performer rpm intake. Powermaster alternator. Trans is a A904 with a hughes converter and hurst shifter. Rearend is a stock 7.25. Front suspension has QA1 upper arms, Bilstein shocks, disc brakes, QA1 strut rods, rear suspension is stock leaf springs. Has a brand new American Autowire mopar A body wiring kit installed just needs to be buttoned up. New wiper motor and wiper arms and blades. Car has some rear wheel well rust and the usual trunk waterfall rust. Floors are solid. Also has new 15” wheels and tires. Clean Utah title. I just moved to North Carolina that is where the car is located. Asking $12k obo
Can you post some interior shots (seats and dash)?
Sorry I’ve been super busy with work and moving. The interior needs a headliner, has a brand new dash pad, decent bench seat and I have a set of corbeau seats that can go with it.
How much HP on 360 engine
How old is engine and miles
What part of nc are located
Thanks
I’m located in Apex, not sure on HP. The short block is stock, it came out of a Durango, I do not recall what the mileage on it was.
What does car need to go to dragstrip and have some fun. I am 69 years old and looking to start dragracing again.i raced in mid and late 70 ,s
You would definitely want to change out the rearend. Other then that it doesn’t need much.
