1970 Duster Front End and Steering set up suggestions wanted
FDNY340
NY
Greetings Gents!!
Have a 1970 Small Block Duster that came with a modified K member (Bobs Pro-Fab) and front suspension (tubular upper control arms... unknown brand). Dont have any info on what they are but Im looking to upgrade manual steering and front suspension. Who are the gurus?? Car is back halved and will be mostly street with occasional track. Not looking to do power steering but definitely looking to keep the car in one lane at the track!!!
Thanks in advance!!!
I am not a expert, but I would recommend engine limiters with the engine plate, have to get everything assembled at normal weight. Adjust the ride height and then alignment. I do a race alignment, 0 camber, 0 toe and as much positive caster as I can get, doing the alignment at 2" raised from ride height. Then see what the alignment is at ride height. If the alignment won't adjust to the preferred specs, might have something bent or worn out.
