Here is a bunch of suspension parts for a 1970 Duster. Everything here fits 62-76 bodies with the exception of the upper ball joints. They are large stud 73+. So, if you have changed your front spindles to 5 on 4.5 off of a 73+ A body these will work for you. These will fit many different years and models of Mopars. Brand is Tread Saver which is part of Federal Mogul. Bought from PST in Arizona. Made in USA not Chinese crap. Included are:
2 ea Upper Ball Joints Large Stud for 73+
1 ea Right Lower Ball Joint
1 ea Left Lower Ball Joint
2 ea Right Hand Thread Tie Rod Ends
2 ea Left Hand Thread Tie Rod Ends
2 ea Tie Rod Adjustment Sleeves
Also found the Pitman Arm it will be included as well. Only item you will need is the idler arm. If memory serves, 67 is different, 68 and newer are the same. I can post a picture if needed.
$150 plus shipping from Minden, NV
