[FOR SALE] 1971 340 engine no VIN on pan rail
barracudajohn
whitehall pa
See photos, what you see is what you get. Motor stuck from 40 year plus inside storage. Pistons corroded and rusty cylinder walls, I don't know if they will clean up, or it will need to be bored. To the best of my knowledge, block is standard bore. The J heads were removed from a running engine. An extra set of standard pistons is included. I don't know if this was a replacement motor, but there is no VIN on it. Must be picked up located in ZIP 18038 Danielsville Pa. 800.00 cash.
