****SOLD****
Located in Austin, TX. $2000
bklepac (at) gmail (dot) com or PM
Here are pictures of the car when I brought it home. http://www.ctmrs.com/brad/blue71dart It is a 318 v8 with 904 automatic. No rust in the floors, trunk, or quarters, the only holes are a couple of small ones right behind the rear window on the passenger's side. Small enough just to weld up, don't even need a patch. It only has 45,000 miles on it. The body is straight and all the chrome looks good.
Since these pictures it has 4 brand new BFGoodrich Radial T/As on the stock wheels that I sand blasted and painted metallic blue. I gave it a complete tune up, new starter, fuel pump, belts, hoses, rebuilt the carb, put in a new gas tank and sending unit. It runs pretty good now, and I have put it in gear and it sounds good. The car has 71 Cuda buckets in it already,which need to be recovered, but are complete. I am in the middle of putting all new brakes and rubber lines on it, which I will finish up and make sure it drives before it leaves my possession.
****SOLD****
****SOLD****
