1972 Dodge Dart
WesPitch746
Shelby NC
I am needing help with some wiper motor/wiper arms information. I have a 1972 dart. The motor I have had just rebuilt is a 3431532. I am needing to know the correct part number for the wiper crank I need. I have already pressed in new bushings in the wiper linkages. My linkages have the small white bushings in all 4 spots. I have seen some that take a clip style in one end maybe??? I have done tons of research and I am really confused.
Your 72 should have the clip on links. They switched to the 4 nylon bushings in 73. You can use the later setup (although far inferior) but you need to use the crank from the 73+ setup along with both links. You cant mix and match them. To further confuse you, the two links are different for 2 speed vs 3 speed wipers.
Both of my wiper pivots have part number 30191. One wiper linkage is part #3431688 and the other is #3431685
I’m thinking my build date is after 6/72. Some stuff is showing it being right for my car. But if the older ones are superior I assume do it right once and be done
