townsend will likely have specific info.
in the meantime, familiarize yourself with the service manual.
The edition from Mymopar shows the ECU ignition on a seperate diagram. Unless there is a service bulletin, it will be up to you to combine the two diagrams.
What you are looking at may be an engine connector. IIRC they show up in the '73 diagrams but for '72 mayb it was eitehr a mid year or just didn;t make the service manual diagram.
The bulkhead connnectors are keyed on the engine bay side. Each connector can only fit in one location.
The cavities are called out on the interior.
Standard harness - points ignition
J3 is ignition start
J3A is power to coil, whether in start or run.
Those two connect together at the 0.5 ohm resistor terminal.
J2 is power for the engine to run. it is hot with the key in run.
It must connect to the other J2 segments. such as J2A, J2B, J2E
According to the diagram, it is joined at a welded splice. However you may find some are connected at a terminal as shown in the points diagram.
J2E segment goes to the 5 ohm resistor, and then a short wire jumpers it to the 0.5 ohm resistor. 0.5 ohm resistor is for the coil. 5 ohm resistor was to control power to the ECU on the original ECUs.
J2E supplies power at system voltage to the ECU. That is needed on all ECUs.
J2B goes to the sensing terminal on the voltage regulator. That is critical for the regulator to work. With no connection the regulator will not regulate.
J2C goes to a field terminal on the alternator. That is critical for the rotor to get power.
R3 connects from the other field terminal to the regulator and acts as the return from the rotor. The regulator will control the field current by lettting R3 connect to ground as needed.
