1972 Duster Roller Project
alan627b
Omaha Nebraska
Rating - 0%
0   0   0
Posting this to try and judge interest...my eternal project 1972 duster drag /pro street car. Bought back in 1985. Originally a 318/auto/ 8-3/4 car from Alaska. Column shift auto. Tor-Red with black stripes.
I bought it with the intention of making a drag/street racer out of it. Had a 6 point bar installed, later upgraded to 10 point. Aluminum sheet sealing off the trunk area from passenger compartment. Heater area sealed off as well, but can easily be put back for street use. 2X3 square tube frame connectors. Springs moved into the rails using the then DC relocation kit. Car has been tubbed but frame rails are in stock location. Flat towing (remember doing that?) tabs and tow bar also fabbed. Track locator bar added too.
New 1/4 panels, 1 repro, and 1 OE cut off of of donor car, and tailight panel replaced due to rust/dented condition of the originals. Rust was in lower 2 inches of the quarters, and under the tailight openings.
Quarters have had the front edge of the wheel well moved ahead 2 inches for tire clearance, anticipating using a 12.2 or 11.5 slick. Should fit a 14X32 with a narrowed rear axle.
Floors and trunk have no rust. Engine compartment has surface rust only.
Spare tire well removed, sealed with tin, fuel cell installed. Although it was a low budget one, that I would replace it with a bottom exit one with safety foam in it if were doing it now.
Dash/heater/defroster gutted, floor shift steering column installed.Stock bench seats discarded. "Craftsman" who added the last 2 bars to the cage did not believe in masking the windows and weld spattered them badly, but I have complete replacement glass that goes with it, from a buddy's Duster that went the Lexan route.
If memory serves, it was once a P/S car, but has stock manual box in it now.
If someone wants it, I am going to put a fair amount of spare parts with it, pretty much all the Duster stuff I have for it.
Very good Sharkstooth grille and buckets.
Stock grille as well.
Partial 70 Rallye Dash and cluster.
Car has 4 inch bolt pattern now, but can include Moser cut down C body axles with Green bearings and 4.5 bolt pattern. Rear housing is stock width.
4 rebuilt drum brake assemblies with all new Raybestos /Napa parts.
DC rear spoiler, not the Go-wing type.
Stored inside since 1985. Located in Omaha, Nebraska.
Alan Hynes alan627b@hotmail.com
Would like to get $3500.00
I have all the receipts for anything done to it or bought for it. I need, not want, to sell it due to the fact that I don't have enough time to finish it, and would like to use the money to further the Valiant that I have.
Gonna post some pics so you can see what we're dealing with!
Thanks for looking,
Alan
Few more pics. Rallye dash does not have the wiring, just missed getting it all at the swap meet....by about 10 minutes. Door has dent damage, another good rust free door comes with it. Can come up with most or all of the under dash stuff if required. Clean title in my name . Also comes with additional floor shift column. What I always called the "clink-lock" safety depress type as displayed in the photos. I'd prefer to keep the Tuff wheel for the Valiant, however.
Only stuctural defect in the engine bay, is the split where the battery attached, as seen in pic 1 below.
K frame is the original 1972 V8 version. Have all the original wiring, not to worry!
Let me know what you think, but please be kind!
Alan
Due to lousiest work season since 1993, and recent work injury, I really have to sell this car. Still available. Open to realistic offers, but I'm not going to give it away.
Alan 6727b@hotmail.com
Alan Hynes
402-896-0261
402-250-9866 cell
Thanks folks.
Car has been sold,thank you for looking, thanks to A Bodies Only for the post. Got $2800.00, and I kept the Sharkstooth grille. Should be tearing up the street/strip in a year or so.
Alan627b
