[FOR SALE] 1972 Plymouth Duster 340 Racecar
quartermilepass
New Jersey
Rating - 0%
0   0   0
Hello all. I am seeing if anyone would even be remotely interested. Have a 1972 Duster Racecar for SALE OR TRADE can add cash if need be Will take offers
Motor
340 earlu 70s
H-beam Rods
forged pistons
Edelbrock aluminum heads
Valves seats springs retainers keepers all redone to fit a bigger cam
Only running small cam for now .510/.510 cam new pushrods lifters
adjustable rockers
compressions 180 on all 8 cylinders
850 carb
new headers with evac setup
msd setup ( box coil distrib wires )
Car runs 11.80s all glass all metal ( except hood ) car can take upto a 57x cam with just a pushrod change we measured it all out also you can add nitrous to the car and is built to handle it. I do not know what it would run on nitrous i never ran it with it.
Fuel
Magnafuel 275 pump with built on filter
We ran all big fuel lines for a big block since that was the plan had a return fuel line and fuel regulator. little bigger then a 5 gallon cell
Trans
727
built 3 months ago with transferable warranty
sprag clutches everything done
body
Repainted last april
Car was brought down to bare metal no rust
does not have original dash in car, aluminum dash ontop of the original dash supports. ( have a dash that goes with it ) 72 dash
Gauges are new with all the wiring and in the car
new shift cable
Racing seats
All glass windows with chrome trim
2 brand new triple chrome bumpers front and back on the car
Also have 2 fiberglass bumpers to go with it
2 sets of original grilles one is original color 1 is all black
Sharktooth Grille as well in good condition all lights work.
Has just lenses in the rear for tail lights, I purchased the whole harness to make the original lights work along with 2 extra housings and lenses
new trans cooler
Electric fan electric coolant pump all wired with switches and fuses.
Fiberglass liftoff 4 inch cowl hood
car has a roll bar
More drivetrain
Whole front end was just recently don't with polyurethane bushings new bump stops and upper/ lower balljoints
Front tires have 50 passes on them
rear tires are 27x10.5
Front brakes are disc rear is drum
Rear is an 8 3/4 leaf springs moved in 2 inches has 4.10 Richmond gears along with a spool inside the pumpkin
Line lock setup
Few extras I have
original Door panels from a 72 Duster front and back sets color black.
New carpet in the box ( front only ) for now
comes with both sets of bumpers new chrome and fiberglass
Both sets of original grilles
Can answer all serious questions ( Please pm me questions may not see this post alot but pms go to my phone as well ) $ 14,000 New Jersey
Can also add in a 440 shortblock that went 11.0x in a 4,000lb car this car is est. under 3,000
WILL TRADE FOR STREETCAR CAN ALSO SELL CAR LESS MOTOR AND TRANS
may even consider a nice fastback barracuda,
send me offers on car have plenty of different motors or packages to get car cheaper or roller, would even trade car t/k for a nice roller.
Able to sell as roller or turnkey for a nice roller.
A bodies b bodies e bodies challengers or something cool. Just ready for something different.
had a couple messages for more pictures so figured instead of a bunch of messages I will just add them here
