Food for thought................
Probably 10 years ago or so Freiburger, in "Car Craft" took a sick, tired, weeezzzing 318, put what I seem to recollect was a 250hp shot to it with the intent to blow it up and it didn't!!
Stock rod is pretty tuff.............proper clearances, I think are far more critical. To be sure, mag them, check big end, rebuild as needed, use good bolts.....or not. I'm pretty unconventional in this regard; any rod I've seen that lead to an oil pan failure has never broken a bolt; not saying it can't happen, I just think it's something else that broke and by the time pieces stop flying, the bolt gets blamed.
Question is what kind of rpm are you gonna turn this? What is your piston? If you go to an after market rod; what are/would you use?
As I said, just food for thought.
Good luck with what ever you do.
