moparmarty
Member
12 Second 4-door. Car runs 12.50's with best of 12.45. 17" Boyd Wheels,360 .030 with KB107 pistons, HEMI-Grind Cam, heads - stock with bowls opened & blended to accept 2.02 int & 1.60 exh valves, Port matched, Edelbrock Air-Gap intake 750 DP Holley, Aeromotive fuel pump, MSD 6AL box & distributor, 1 5/8 headers, custom exhaust with flomaster mufflers, transmission - 904 performance built, dynamic 9.5 convertor & turbo action manual valve body, B&M carbon fiber shifter, rear axle, 8 3/4 with aftermarket axles, 3.91 SUREGRIP, Autometer gauges used in place of stock cluster, autometer tach, seats; aftermarket buckets, rear seats covered in matching material. Too much to list!!! If you are looking for something different and fast this is the car for you!!!! Car must go for other projects.....
Located in Sand Springs, OK
$6500.00
PM me for any questions
$6500.00
