Blue73Swingr
New Member
Hey guys probably a dumb question but I searched thru the tech archive but no dice.
I just picked up at 73 Swinger, with a slant 6. The windshield washer motor was not grounded properly so that fixed that issue, meanwhile, I found the arms under the the seat. In looking at my buddies 73 I figured out how they are hooked up but neither his nor my car has all the hardware that attaches the linkages to the pivots and then the motor. I removed the glove box and was able to get the arms back in place.
I believe Classic Industries catalog calls them Wiper Pivot Gaskets, and lists that they fit 67-76 models. On another forum a member mentioned you can pick them up at NAPA at a fraction of the cost, no part number was given.
Is this what i need to attach the arms or are the gromets or gaskets called something else? Anyone have a part number from the box stores or Mopar?
Secondly the plug that connects the column to the main harness had burned up the middle of the connector and someone previous to me bypassed the red and black wires that I assume provide power to the ignition. When you move the connector around it kills the motor while its running.
Short of finding one in the Junkyard, or bypassing the connector? Anyone know if these are reproduced or ??? I would like to fix it correctly instead of jerry rigging it or at worst case bypassing the connector and hard wiring it. Obviously I need it to be reliable.
Thanks!!!
:burnout:
Thanks!!!
:burnout:
