PAY ATTENTION to what Redfish posted above^^
There are several issues at play when overcharging
"In no particular order"
There could be some "weird" thing going on with your alternator--loose bearings / shaft play, I know not what--that are somehow causing something to move and ground the VR connected field. But that would be a stretch
Not sure what might be RPM related--check the belt!!!
So far as "the rest of it" I've written dozens of times
VOLTAGE DROP!!! Make certain that the VR is actually AT battery ground, and make sure VR IGN terminal is "same as battery" --and they usually are not
1...Make absolutely certain VR is grounded. Remove, scrape around bolt holes, re-install with star lock washers. Not a bad idea to add a no10 jumper from the VR mounting bolt to the block
2...CHECK the VR connector for corrosion, and work it in/out several times to "scrub" the terminals and "fell" for tightness
3...In your case, remove and carefully inspect the brushes and slip rings for condition, impacted dirt/ grease etc in the brush holders, any oddity that might indicate a problem. Look up in the shop manual and do a field current test
4...To check for voltage drop, turn key to "run" with engine stopped. Stab one probe of your meter into the top of the battery + post. Connect the other as close as you can get to the VR IGN terminal, which is likely the ballast "key" side. This is the two terminals at one end of the ballast with a short jumper in between. You are hoping for a very low reading, the lower the better. Anything over about .3v you should try to see what is happening. One "workaround" is to add a relay to feed the ignition/ VR power. Cut the "ignition run" coming out of the bulkhead, use the bulkhead end to feed a Bosch relay. Connect the power contact through a big fuse/ breaker to the starter relay stud or other "solid" battery point. Connect the remaining contact to the engine bay end of the "run" wire you cut. Ground the other end of the relay coil
5...To check VR GROUNDing.......run engine at fast idle, and make this check with all accessories off, and again with everything on--blower, lights, etc. Stab one probe into the battery NEG terminal and the other into the VR mounting flange. You are hoping for a very low reading, and zero is perfect
