AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,913
- Reaction score
- 12,265
the Fast idle cam will be your friend.I cant keep it running long enough to do that hahahah. im working alone.
The PCV is a controlled air leak. You can pinch it off. If the idle speed goes up, you probably have a leak somewhere else; if it goes down,probably not.
The choke blade is an enrichener. So is a rag over the airhorn. If you begin to close off the air intake, and the rpm goes up, she's getting air from somewhere else that she shouldn't be...... Or the valve timing is out,lol. Or the valve springs are really weak.
For now; just loosen the distributor, grab the Vcan and pull on her to give it enough advance to idle. Dont't worry about the numbers, it's really hard to over-advance at idle. Just pull until the idle speed stops rising or the can runs into an obstruction.
